Experimental data
Experimental data
Hi all,
I am trying to make a hyper elastic simulation of a polypropylene shell.
To characterize the mechanical behavior of this material, I make tensile test in two directions (longitudinal/transversal), the measurement are very different.
My question is: if it is possible to create an anisotropic model with this experimental data?
Thanks in advance for your help.
Cheers
Cheers
RE: Experimental data
I think you can't define an anisotropic hyperelastic material. In ANSYS, the hyperelastic material models assume that materials response is isotropic and isothermal.
Regards.
