Modify or add Description in PDMWorks
I did a Pack & Go to copy an entire Job to make subtle changes to. I then checked the job into PDMWorks. My Save File Description text needs to be updated now.
Can I Modify or add Descriptions to files after they are checked into PDMWorks from PDMWorks? or do I need to do a Save As to each file individually?
Tom
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: Modify or add Description in PDMWorks
As long as you own the parts and assemblies you can change the descriptions when the part is in the vault
Use SolidWorks Explorer, find the part and select the properties tab you can then change the description or any other property
Jim Self
SW2007 SP3
dlplimited.com
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
