Viewing Results of Only Selected Parts
I would like to show the maximum stresses and deflection of each part of my simulation assembly in Workbench10.
I tried to select the part I need to investigate and hide/disable all other parts but the stresses bar is still showing me the maximum stress of the entire assembly. I need to see the maximum stress of only the selected part.
Need your tips please.
RE: Viewing Results of Only Selected Parts
- in Ansys Classical: select the volume(s), then "select everything below selected volumes"
- in Workbench: create / duplicate a Result object and SCOPE it only to the desired body (remember to issue "evaluate results" after that)
