Glycol Line Wall Support
Good afternoon,
I have a 4 inch glycol line (at chill water temp) that needs to be insulated since it is running outdoors along side a vertical wall at 10 ft.AFF. What is a common insulation thickness for Houston,TX. What is the bright metallic jacket called that is over the pipe insulation. Is it Aluminum or other material. How would I specify this material and the pipe insulation density/material?
RE: Glycol Line Wall Support
I also need any references to find wall support brackets for this pipe-mounted to a vertical wall at 10 ft AFF.
ht
http://www.specjm.com/pipe.php?category_id=11
http://www.knaufusa.com
The pipe could be attached/supported multiple ways, the most common would be a riser clamp or unistrut to the wall.
http://www.anvilintl.com/
The cover is aluminum, and or pvc. To prevent physical damage to the insulation.
Steve
