How do I modify a UDF?
I have a User Defined Feature for a SAE port J1926, but the model hole size is incorrect. The text on the note is correct. Some of suppliers machine directly from the model which is causing problems.
How do I open the UDF so that I can modify it?
RE: How do I modify a UDF?
Just select Tools > UDF > Modify and redefine what needs to be changed. If the UDF was placed as Standalone or Subordinate, you're changes may not take effect.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
