Cyrogenic Manhole
Cyrogenic Manhole
Hi Friend
I have problem with manhole low temperature suction drum in JT/TurboExpander section. The Design temperature minus 80C and design pressure 78barg. Operating pressure and temperature 62barg and minus 70C. Manholes 20"x600#. All Materials Stainless Steel 316. While shifting TExp to JT valve, the pressure in vessel will increased to 68barg and sabile back to 62barg, and make the Gasket burst, 4 times already happened. Anyone experience on this and what is the solution?
RE: Cyrogenic Manhole
What type gasket?
What is the fastener torque?
Can you explain your design condition a little better?
Bolt Torquing
Design Pressure : 78 barg
Design Temp : -80C
Oprating Pressure : 62barg
Operating Temp : -70C
Liquid HC Condensate Reflux and HC Gas on Top.
