thermal insulation for 90mm pipe
I need to thermal insulate a 90mm diameter pipe, the pipe is abot 3m long. In order to do this I would like to use preformed foam which I only need to slip over the pipe. Armstron armaflex offers such systems for smaler pipe diameters. I an not find any manufacturer of such afoam for bigger tube sizes. The max tem is about 90°C. does anyone know a manufacturer, preferably in the U.K.
RE: thermal insulation for 90mm pipe
Armaflex should be available as tube to 6" NPS. Your temperature is getting close to the max recommended temperature 105C.
