CRUDE PREFRACTIONATION TOWER
Please recommend for materials of construction for a crude (28.7 deg. API) prefractionation tower operating at 4 barg and 150 C (top) 230 C (bottom), carbon steel with a large corrosion allowance or use carbon steel with ss clad?
regards,
        roker
RE: CRUDE PREFRACTIONATION TOWER
Roker,
It certainly depends on crude corrosivity, i.e. salts, water, naphthenic acid, H2S and other aggressive agents. Cladding is - as far as I know - very acceptable and effective approach. But I would definitely suggest you to consult experienced corrosion engineers and to examine the worst possible scenario regarding feed quality and corrosion mechanisms that may occur.
