part Origin change
part Origin change
part Origin change
When importing a model from other CAD packages sometimes the origin isn't were I'd like it.  How can I change this?
I've had a look using search, but didn't see what I'm looking for.
It's likely a very basic question, but it wasn't covered during training.
Andrew.
RE: part Origin change
Depends on what version you are running and what you want to do with the origin.  If you are using V19 you can use Move in the Modify commands to move all the geometry to a new location relative to your base planes.
You can also create a origin anywhere you like but the geometry will remain in the same position relative to the base planes.
Thanks, I run V19, however can I also rotate the part relative to the origin and base planes?
In the same manner, can I also rotate move assemblies relative to the origin and base planes?
Assumng only the first part in your assembly is grounded and everything else is related to it or another part, then yes you can move and rotate the entire assembly.
there are at least 4 ways of doing this  :
1. RMB on the first part and select Occurrence Properties. You will be presented with a table showing XYZ position of the part, XYZ rotation and various other parameters.
Simply enter new values of XYZ etc to move and rotate the part to where you want it to be. The value fields will do calculations for you, so if you wanted to move 500mm along positive X direction, just type in +500 after the value that's already there (delete any units characters such as in or mm).
2. Delete the ground constraint and use the move command, the re-apply a ground constraint. Note that if you only SUPRESS the ground constraint, the part will move back to it's original location if you unsuppress it again.
3. Delete the ground constraint and apply relationships between part faces and the base reference planes.
4. Create a co-ordinate system in the part file. Then create one in the assembly file. Now use the match co-ordinate systems option in the assembly to locate the part in the assembly. You can change the positions and orientations of each one as you require.
Hope this helps.
bc.
