What is an Induction Box?
Hi Guys,
I am looking at some old plans (around 1971).  THey show a few large boxes as induction boxes.  What is the function of this box?
thanks,
RE: What is an Induction Box?
An induction box, or unit,provides a jet of air at the box, which entrains room air. The entrained room air mixes with the air from the jet of air from the induction box and mixes temperature. A small amount of air at high velocity from the induction box can cause a much larger quantity of air to flow in the direction of the induction box jet stream. The supply from the induction box might be 45 deg. F for instance and mixed with room air will create a flow of both induction box air and induced air to provide a comfortable mixed air temperature of 55 to 60 deg. F. air.
The induction box air, is usually comprised of mostly ventilaion, ie. outside air.
Steve
Where there is a fixed requirement for fresh air, induction works a charm. I've used them mostly in hospitals.
Used to be many makers....only one now I know of.
