Well I Never (Oreintation)
Cannot believe that I stumbled across this accidently but I guess loads of you knew anyway.
For those that did not.
If you wish to reoreint your 3d model quickly especially if you say are looking from the right side and you wanted the left side.
Look closely at the compass where you see the x, y and z text on the appropriate axes.
If you highlight the x text and click it will either reverse the orientation or orient your current view to the Left View.
Also it will not do it dynamically but instantaneously.
Nev
Nev
RE: Well I Never (Oreintation)
If you always rotate your parts parallel to the screen, another little trick you might like is VIEW + NAVIAGATION MODE + VIEWPORT SNAPPING and then try rotating your part.
Texaspete
vikingcadjocky
