Preventing radial or axial movement in a steel sleeve in aluminum part
How can I install a steel sleeve into an aluminum part and prevent it from moving radially or axially? It should be mechanical in nature like staking etc? I can provide pics or sketches if required.
carljessome@gmail.com
RE: Preventing radial or axial movement in a steel sleeve in aluminum part
Mike Halloran
Pembroke Pines, FL, USA
If the purpose is to provide a good locating bore and proper support for a ball or roller bearing, it is a good idea.
Harley Davidson and others do this with a cast in insert http://i8
Installing the sleeve with an Initial interference greater than expected thermal expansion of aluminum housing is an initial requirement.
http://www.connexusa.com/
http://w
http://www.usatolerancerings.com/history.html
Russell Giuliano
Pics or sketches would be helpful.
Mike Halloran
Actually, thank you to all for the posted answers. It gets us doing more thinking. Still nothing we can use...yet.
Please send more ideas.
The split bearing ideas are cool, but there are seals on the part that fits inside so the line would create a cut situation.
I'm sorry, but I feel a little like I'm playing that insipid US game show with Howie Mandel, (http://www.nbc.com/Deal_or_No_Deal/game/) having to guess wildly, but without even the benefit of "models" to look at.
A flanged insert would not move axially in one direction.
http://eng-tips.com/faqs.cfm?fid=1100
