electrical routing (wiring harness, no refs)
I have been tasked with creating wiring harness drawings from a given example of that harness.
so for my models i dont have a reference to run the wires from and to. I am just looking for the best way that i should go about creating these drawings.
I have looked at simply creating drawings without assemblies however i then need to specify the wire and wire lengths etc.. in the BOM.
any suggestions would be much appreciated.
thanks
RE: electrical routing (wiring harness, no refs)
tha89sx,
This is what we do here in our R & D department. Since we don't have SW routing add-in, this is our method.
Engineering Design:
Put the connectors were the need to go in your design in a SW assembly.
Example:
Engineering Detail Drawing:
Use sketch geometry to drawing the wirings in 2D views:
Example:
The folks in the assemble lab will build an actual harness to this, and then give the engineers the wire lengths to build an interconnect wiring list.
Example:
Other SW eng-tip users may have a different approach. I hope this helps,
Colin
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 4.0
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
Nice approach.  We tag all our harness 3D models "For Model Only" and use a 2D drawing for actual manufacturing data.  We do basically the same, put connectors in teh air where they need to go, then group them as the harness part number.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
That's very similar to the way I do it, except I create 3D sketches for the wires. That way I don't need to add 2D sketches to the drawing vies and, if/when needed, the 3D sketches can be used to create sweeps.
cheers
CBL,
You can also get wiring lengths for your method. I really don't have time to do this procedure. Plus the guys and gals (mostly the gals) would comment and say I didn't have enough wire length added. And you don't want to mess with women. LOL!
Macduff spin
Colin Fitzpatrick
You can model the wire... 3d sketch & sweep... whatever method you prefer. Then set your part density to match the real wire. Then use the mass of your model to calculate the real length.
Quote (Jack L Tate):
Right-click. It's friggin' magic!
FAQ376
Windows XP / Microsoft Wireless Optical Mouse 5000 / SolidWorks 2007 SP2.2 / SpaceBall 5000
www.Tate3d.com
