SolidWorks Explorer 2007
Is there any way to disable the preview display? (The bitmap image) or at least have the default automatically show the e-drawings view. The bitmap image sometimes take a long time to load especially if it is an AutoCAD drawing or if it is a unrecognized format. Sometimes it even crashes. I've tried moving my temporary viewing directory to different locations with no luck.
Sean
Carmanah Design and Manufacturing
Vancouver, BC, Canada
www.carmanahdesign.com
RE: SolidWorks Explorer 2007
Un-Click "Show Thumbnail Graphics in Windows Explorer".
This should put the generic solidworks part/drawing images instead of the thumbnail preview. This only affects the images you see when you 'Open File' through Solidworks.
If you open the actual folders using Windows Explorer it will still display the thumbnail previews.
Hope this answers your question.
Lou Monaco
www.gledinc.com
If you Un-Check the box as noted above,
When you re-boot your computer the change will affect all of the thumbnails in the Windows Explorer folders as well.
-Lou
Sean
Sean
