Line color/weight won't show up on new layer
I am working in Microstation V8.
Occasionally when I add a layer, the lines on that layer show up on screen as thin white lines instead of the color and line weight I want.
The lines plot at the correct weight in B&W, but show up thin and white on screen.
This only happens sometimes.
Any suggestions?
Any suggestions?
RE: Line color/weight won't show up on new layer
On each of the Level, Color, Style is a bylayer setting that you will need to click on.
Namdac
