search function
search function
search function
Has the search function stopped working? I've searched some pretty simple terms, and it always says "not found".
David
RE: search function
The search function works fine.
What are you searching for, and how are you searching?
It's hard to offer you help given the info you have provided. It really just sounds like you're complaining.
RE: search function
Not working for me either.  It will search other forums but not "PTC: Pro/ENGINEER Forum".
I wonder if it's a syntax thing and the search utility doesn't like the ':' or '/' in the path...
<tg>
RE: search function
I searched for "BOM" and "balloon" among other terms... Just tries again with same results.
David
