Draft view borders
Draft view borders
Sometimes I have brackets around the draft views. They appear as light grey in the corners. What are they and how do I remove them?
Jef
Jef
RE: Draft view borders
they grey corners denote that the underlying part needs
to be updated.
Check --> Tools --> Drawing View Tracker
for information which parts must be updated.
dy
Problem arose when I brought a model home without using Insight. A file lost its link.
Jef.
Also occurs when mass properties of the assembly and sub-assemblies are out of date.
When I update parts I try to do so using edit in place from parent assemblies. On returning to the parent assembly I would then do CTRL+U to update all relationships, followed by a mass prop calc.
bc
