.7 Volt diode drop
.7 Volt diode drop
Hello all, Im currently working try to take current measurments off of several motors and etc. I have a Hall effect current sensing ring that was found cheap at digikey. Problem being tha the unit that recieves the input on this unit will only accept a DC input so we installed a diode and a cap to rectify the voltage but the .7 volts that are being droped is too much of my signal as it is only 4.7 volts to begin with any suggestions
RE: .7 Volt diode drop
Dan - Owner
http://www.Hi-TecDesigns.com
Keith Cress
Gunnar Englund
www.gke.org
Sometimes I only open my mouth to swap feet...
