Applying displacement BCs to nodes
Not sure if I am going to be able to explain what I want here, but here goes.
I have a model, part of which I need to remesh to get a much finer mesh. Try as I might I cannot get the seeding right for the mesh to propogate properly and give me a nice coarse mesh far away from this region using bricks. I always end up with either far far too many elements and/or badly distorted elemnents as the mesher tries to get round changes in geometry. I have been advised it is best to chop the model up and rejoin using ties, such that each part can have its own mesh. This sounds ok but can it be taken one stage further? Tell me if this is possible:
I put partitions in as if I were going to split the model into several parts, but don't split it and leave it as a full model. Then I apply a decent mesh, enough to get a pretty good result for overall displacements of the various parts of the model. I therefore have an odb with nodal displacements for the full model. I then go back and do the geometry cuts to remove the unwanted parts of the model and give the new part a finer mesh. Is it then possible to apply nodal displacement boundary conditions to the parts of the model which would have been ties in the other method? I realise there will be more nodes on these faces with a finer mesh so I am assuming some interpolation based on x,y,z coords will need to be done.
I bet this is as clear as mud.
RE: Applying displacement BCs to nodes
Tie surface give noise to the results I believe. So tie surface close to the area of interested need should be avoided. (Tie used to be quite bad but I think ABAQUS have introduced the surface to surface tie which supposed to have less noise).
However, I still prefer to avoid using tie unless I have to use it, but that just my personal taste.
Submodelling will likely save you considerable time and efort.
