Seal Welding and Strength Welding
Can anyone please explain the difference between seal welding and strength welding of heat excahnger tube to tube sheet joints.
As far as i understand Strength weldg is determined by performing a mock up of the joint followed by push out test.
RE: Seal Welding and Strength Welding
Have you looked at UW-20?
A strength weld is provided "to carry longitudinal tube loads", and it also provides additional leak tightness. The procedure is essentially the same as a seal weld, except the tube hole in the tubesheet is beveled (ie. 45 deg bevel or j-groove) to allow filler metal to be deposited. Generally, this is a 2-pass weld.
