Pump Mechanical Thermal Relief/Purge Valve
I am looking for the above valve similar to one/part #7685.
http://www.jeadams.com/pdfs/20_pressurereg.pdf
But, the opening temperature should be 115 or 120^F instead of 140^F.
Do you have a good vendor source or advice?
Thank you!
Thank you!
RE: Pump Mechanical Thermal Relief/Purge Valve
