Chemical resistance of 304/304L
Does a lower carbon content for stainless steel 304L (instead of 304L) also has an influence on the chemical restistance?
Chemical resistance of 304/304LChemical resistance of 304/304L(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Chemical resistance of 304/304L
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
In our case we have one process where we oxidize organics with HNO3 using 304L SS as the primary MOC. There is direct relationship between the general corrosion rate experienced and the %C in the base metal. Historically as the processing of SS has improved we have continually decreased the max. C when specifying 304L stainless steel from 0.030/0.035 to the present max. of 0.015.
This effect is most evident in our large 304L storage tanks. We map the location of each plate and compare the corrosion rate on each plate vs the chemistry.
In another process where we remove organic peroxides we again used 304L with with carbon as low as obtainable.
In most services though the reason that higher C material does not preform as well is that it is not annealed fully. If you use an electrochemical test for determining senitization you will be amazed (dismayed) at how badly annealed commercial product can be. Even 304L from mills often has trace amounts of carbides in grain boundaries.
Rust never sleeps
