Formatting Problems
Formatting Problems
Formatting Problems
Maybe someone can help....
I have created a simple macro that copies a worksheet (in the same workbook)and inserts a new worksheet.  However, the format is totally different.  The copied worksheet is landscape, but when it copies and inserts, it changes the column(s) dims as well as portrait.  Also paste what ever you filled out on the original worksheet.  So I just need a few tips on how to eliminate the data after it is copied and how to fix the format problem I am having.
Macro for copying the worksheet:
Private Sub CommandButton1_Click()
 ' IF YOU REQUIRE ADDITIONAL PAGE OF "MMD"
 Sheets.Add
 Sheets("MMD").Select
    Cells.Select
    Selection.Copy
    Sheets("Sheet30").Select
    ActiveSheet.Paste
End Sub
Thanks a bunch
RE: Formatting Problems
Oh, one more thing,,, this is all under a command button that I created!
Try this:
CODE
 Sheets.Add
    Cells.Select
    Selection.Copy
    ActiveSheet.Paste xlPasteAll
    Application.CutCopyMode = False
End Sub
Thanks for the reply and it seems not to like the ActiveSheet.Paste x1pasteAll input.
However, I did create a keyboard shortcut formatting and it seemed to work...
Again, many thanks
That's not x1pasteAll but xlpasteAll where xl is short for Excel.
Cheers,
Joerd
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
