Node connection
Node connection
Node connection
Hi everybody
Firstly,
If we want to tie two parts via nodes, we must have those nodes in commom between the two elements ?
Secondly,
How to create nodes in specific locations. I tried to use Reference points without success for the moment
Nadir
RE: Node connection
Nadir,
In a tied constraint you define the allowable distance between geometry to tie.  Therefore, you do not need coincident points.  Hope this helps.
Rob Stupplebeen
RE: Node connection
Ok. But why there is the possibility to choose nodes as tied regions?
Nadir
RE: Node connection
and I need to connect my geometries only on 4 points
RE: Node connection
Can you use the Partition Edge to get the node in the wanted location?
RE: Node connection
I tried it but a new error appears saying that the slave surface doesn't exist. For the problem, I have used a rigid body with a reference point as a center of the other points and it works 9for the momement) :)).
Regards.
Nadir
RE: Node connection
After you partition, you will likely need to go back and re-define your constraint/interaction/tie with your newly partitioned model.  Otherwise your original edge/surface data will no longer be valid, hence the new error message.
