Temper curves for EN25 & EN26
Would anyone happen to have some temper curves for EN25 & EN26?
We have one set of curves for EN25 and two sets for EN26. The curves for EN25 are showing suspiciously high Izod toughness values, and our curves for EN26 show different tempering temperatures by 100degC. So we're in a bit of a mess! Trying to get this data from the steel manufacturers is like getting blood from a stone (I've tried everyone I can think of).
Even just a quote of what temperature the worst temper-brittleness occurs at for EN26 would be a big help.
RE: Temper curves for EN25 & EN26
Sorry, I used terminology from my workplace. I'll try to rephrase things.
The curves referred to were supplied by the steel manufacturers, and show how the material properties vary with tempering temperature, after being soaked at 850degC and quenched. I suppose the best way to explain what I'm searching for, is to say I'm after the EN25 & EN26 equivalents of the type of charts found here:
www.atlasmetals.com.au/Alloy_Steel_Bar.asp
If you open the PDF for 'Atlas 6582' you will find a similar chart on the third page, although it lacks Izod toughness in that example.
The testing & application would be at room temperature. The data we have does not say what the sample geometry was.
Thankyou.
