NEC reference for bringing existing installations up to code
What sections of the NEC state requirements for when you have to bring existing wiring up to current code? I just have a hard copy and the table of contents and index aren't very helpful.
RE: NEC reference for bringing existing installations up to code
Don Phillips
http://worthingtonengineering.com
Recently I came across some remodeling work was not definitely not up to code (splices made with just electrical tape and not physically protected). Thus my interest in understanding NEC implications for the rest of the electrical system this problem is addressed.
Talking with the local inspector is on the 'to list'.
Now finding an old code violation can vary from state to state. In most states, code violations are misdemeanors which have relatively short statues of limitations - like two years in Ohio. If the violation is past the limitation, the building official will not have authority to require its correction unless it is an imminent danger. An improper splice, personally, I would consider an imminent danger and I would order its correction if the owner/tenant/contractor refused to correct it. Most good electricians I have worked with in the past would strongly recommend to the owner that it be corrected or, if they are making enough money on the job, just fix it and eat it.
Don Phillips
It is generally limited to the area you are disturbing. You got to read codes and if still have quesitons, it needs to be reviewed with appropirate authorities having jusrisdiction.
How far "back" into the existing electrical system do I have to "fix" because of a new addition or renovation project?
I always try to have a meeting with the local Authority Having Jurisdiction (usually the local electrical inspector and/or the plans reviewer) on site to go over the situation with them and seek their input. I explain the existing system and its deficiencies, then explain our upcoming project and how it impacts the existing system, and lay out my approach.
Then, after all is said and done, I do whatever they say.
But, usually, a well laid out plan is well received by most AHJs.
Good luck.
CJCPE brings up a good point about selling the property. Some townships require inspections (and possibly upgrades) as a condition of any home sale.
