Equation woes
Equation woes
Situation:
I have a part that is modeled in-context of an assembly. Basically a C-Channel. Its extruded depth is linked to a "layout sketch" in the c channel part file. The layout sketch is linked in-context to a sketch in the assy.
Problem:
I need a pattern of holes, equally spaced along the c-channel. This is created with a linear pattern as the number of holes could change as the overall length of the channel grows. I don't have an extruded depth dimension to use in the equation. So I put a ref dimension in the layout sketch (first feature in the tree). Then I can use it to drive hole spacing in the equation. Problem is it takes 2 rebuilds for it to update. In the assembly it won't update the pattern at all, just the length of the part. Not sure why this is
Bug, limitation, ER ????
Problem:
Jason
SolidWorks 2007 SP3.1 on WinXP SP2
RE: Equation woes
"D1@LPattern1"=("D1@Sketch1@Assem1.Assembly")/"D1@Sketch3"
RE: Equation woes
RE: Equation woes
http
Fill Pattern won't work as it doesn't have enough control.
Ultimately I need it to calculate an "if/then" type statement in the equation. As the spacing grows, holes get added such that the spacing never gets larger than a certain amount.
Jason
RE: Equation woes
I often have a similar situation as I model a c-shaped sheetmetal components with have a series of profile cutouts and bolt holes whose qty and spacing are dependant on the overall length of the component.
The solution that I use is to use two sketches to drive the feature. One sketch is the cross-section of the component and the second is a line which runs in the direction of the extrude. I then create the extrude, however instead of extruding to a particular depth or to a plane that has been defined in context of the assembly, I simply extrude up to vertex, the vertex being the end point of the line in the second sketch. This line should be in context to your assembly. In order to get the equations to work, simply edit the second sketch, the one with the line, and add a driven dimension to the line. You now have the dimension that need.
I hope this helps, let us know how you get on.
