Something wrong with formula
Hellow,
What is wrong with this formula ?
if "thickness g" == 3mm {chamfer=5mm}
else if "thickness g" == 4mm or "thickness g" == 5mm {chamfer = 1mm}
else if "thickness g" >= 6mm or "thickness g" <=8mm {chamfer = 1,5mm}
Bad kind of argument number 2 in Operator ==
(should be Enumere Insted of Length
Respect
Amnon
RE: Something wrong with formula
Amnon,
Lots.
1. Do not use quotation marks around the string variable
2. Do not use commas for periods. (assume you are using Spanish keyboard or other)
Anyway this will fix problem just cut and paste into the rule
if `thickness g`  == 3mm
chamfer=5mm
else if `thickness g` ==4mm or `thickness g`  == 5mm
chamfer = 1mm
else if `thickness g`  >= 6mm or `thickness g`  <=8mm
chamfer = 1.5mm
Nev
