Formulas and Parameters
Hellow,
I drew a washer with outside diameter - D(PartBody\Schetch.1\Radius.1) and inside diameter - d(PartBody\Schetch.1\Radius.2), I'd like to use formula PartBody\Schetch.1\Radius.1 = parameter D/2 but unfortunately I can't see PartBody\Schetch.1\Radius.1 in the tabe(Formulas) but only changed parameter D, Can I Switch it on - PartBody\Schetch.1\Radius.1 :)
Amnon
Amnon
RE: Formulas and Parameters
You just have to pick the sketch from the tree while in the formula editor. It will then show you all of the editable parameters for the sketch. Select the dimension diameter, click on "add formula", and assign a formula - in your case, d/2 sounds like it will suffice.
By the way, you don't have to post the full string for parameters. It really just makes it harder to read your post. It would suffice to say, for instance, parameter D=Radius.1.
Catia Design|Catia Design News|Catia V5 blog
