Intrinsically safe barrier
When voltage passes through an intrinsically safe barrier does the voltage change?
RE: Intrinsically safe barrier
Their entire point is to limit the delivered energy.
Keith Cress
The key point is that it must not pass more than the defined "safe" level. Other than that the exact amount of gain/attenuation is not defined. (Ok, typically it would be a bit less than unity voltage gain.)
http://www.mtl-inst.com/support/tp.htm
You will need to register but it is worthwhile.
Sometimes I only open my mouth to swap feet...
