Steam Corrosion on piping & CF8M castings
Application is papermaker.
Low Pressure Steam is not corrosive to the steam piping [mild steel] or the paper machines dryer cans [cast iron].
Why is steam so corrosive to our CF8M electropolished castings?  [very serious corrosion]
Even the SS316L polished shaft is very corroded - why?
Could the reason be because our castings are exposed to air,steam, and condensate?
The dryer cans and piping are not exposed to air but do have condensate.
Salzilla
RE: Steam Corrosion on piping & CF8M castings
All of the impurities will be concentrated in the condensate.
What type of corrosion are you seeing?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
