Force in - force out
I'm trying to develop a mechanical mechanism that will allow 3-6 lbs of force-in to get 18-21 lbs out. Size would be 5sq" X 2” I would like to construct it without using electricity, fluid, etc. Must be portable. Could flat spring material be designed to do this?
RE: Force in - force out
TTFN
In-line or offset forces? Rotary? Input/output stroke lengths involved? Materials? Usage? Cost?
CorBlimeyLimey - In-line, Stroke=2", Materials: any, Cost:?
If its the input you are going to have ~0.5" ouput stroke at 24lbs with 6lbs input.
If its the output stroke you are going to need ~8" of input stroke.
how about 2 facing racks, and two twin gear shafts?
Kinda like:
CODE
------------------ Input rack
OoOo Gears (x4 force -- direction change)
----------------------------- Ouput rack
Nick
I love materials science!
In the case of an amplifier, you can have more force at the same stroke, or even a larger stroke, but you have to have an external source of additional energy, like a hydraulic pump or motor. In this case, a small pressure on a spring-loaded valve can cause massive, though proportional, amounts of force at the output, but it is technically produced by the pump, not the input force itself.
Don
Kansas City
NickE's solution could be made co-axial with a few extra characters:
-[ OoOo ]-
h
h
Full article:
http://en.wikipedia.org/wiki/Crossbow
Something that's unclear is whether you want 20 lb over the entire stroke, which is different than a spring compressed 1 in with a 20 lb/in spring constant. This would give you an inch to put in a crank and rachet.
TTFN
