dry well design
dry well design
Hello, I have a project where the Bldg. Dpt. require to design a dry well for a 15 CF/H condensate drain from AH in a commercial bldg.
Does somebody can help me with this?
RE: dry well design
Richard A. Cornelius, P.E.
WWW.amlinereast.com
RE: dry well design
The civil engineer say that the HYDRAULIC CONDUCTIVITY (K)=7.93E-04 (acording Percolation Test Report)
How I know the FRENCH DRAIN dimentions required?
THANK YOU
RE: dry well design
http
and http://www.cityoftacoma.org/Page.aspx?hid=951 (Vol 5 Chap 7)
RE: dry well design
Since you are dealing with such a small amount you may be able to use a frech drain too. With a french drain you can locate a perforated drain pipe in a 3'W 3'H X'L trench backfilled with gravel wrapped in filter fabric. Size the bottom of the trench area (3'xL) so that 0.714ft3/hr drains at the rate of the K value (7.93E-04 Ft/s? ft/hr?).
