Need Valve Recommendation
I am new to this forum, and this is my first post.
I need a recommendation for a valve used to shut off flow from a material holding tank. There is no pressure other than head pressure from the 12k gal tank. The material is a latex product.The valve gets manually opened at the begining of the shift, and closed at the end.I am currently using 3"npt Apollo Bronze Ball Valves, and I'm think maybe there is another option. The Apollo valves have really gone up in price, and the 3" ball valve can be a bear to operate. We have a total of about 90 Apollo 2" & 3" ball valves in operation, and some with 12 years on them. They do hold up well for us.
Maybe something other than a ball valve ?
Sonny
Sonny
RE: Need Valve Recommendation
http://www.flow-tek.com/
you may consider a handwheel on the 3 inch valves if they are difficult to open/close with lever.
It seems the only concern you have is $$$. Shop around - you may get a better price. Or, ask for a bulk discount?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Good luck,
Latexman
Per your recommendations I am going to use a butterfly valve for this application. I'm going to go with the standard EPDM seat & stainless disc. The EPDM will be fine for the latex product.
I looked at Keystone...looks good. Any other brands that are considered top notch ? ( Made in USA ) Just ckecking my current suppliers & hoping to find one through them.
thanks again,
Sonny
There are fewer and fewer USA valves. The ABZ Valve Co. in Manhattan, Kansas manufactures butterfly valves that are good quality, and interchangable to Keystone valves. Some of their larger valves are sourced from off-shore, but they do have their quality controlled.
www.abzvalve.com
