How do I wrap the Predecessors field in MS Project ?
I'm running MS Project 2003. I am working on a project that has many tasks and the predecessors field is VERY long. Is there a way to word-wrap that field so that I could decrease the width of the field, but still view all the tasks? I have tried increasing the height of the row, but I still can't see all the listed predecessors.
RE: How do I wrap the Predecessors field in MS Project ?
Believe it or not, it is as simple as this:
1. Within your plan, click in the blank box in the left corner where the column headings meet the row numbers. This will select your entire plan.
2. Hover over the little line that separates tasks 1 and 2. You will see your cursor change shape. Now hold down on your left mouse button and drag down. (make it double the height that it is right now)
3. You will notice all rows within your schedule are now taller, and all text within each column will now wrap to the next line.
Hope this helps,
J Black
www.pmconnection.com
