Taped holes and Cosmetic threads apperaance ???
Running 2007 SW  ( SP2)
I have noticed that when you have a "taped Hole" that it doesnt always simulate  as such.
 I have been going back and trying different options in the dialog and it does well for the drawing showing the minor and major diameter..
 I have made sure that Annotations is "ON"..  "SHow All" also..
Other times I create a a model and it works well..
Is there a bug and has anyone else experienced the same.
Comments please
RE: Taped holes and Cosmetic threads apperaance ???
Do you mean 'tapered' or 'tapped' hole?
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
'tapped' hole
I have not experienced problems with cosmetic threads, other than not being able to adjust the appearance to a realistic image. But that has been for the last few versions.
Can you update to latest SP?
Are you video card and driver SW certified?
cheers
I have found that sometimes reassigning the material clears up this issue...
