GRIP program to read points coordinates and output to file
Anyone who could help me with some source code for compiling a program to be used in NX3 or NX4?
The function should be like this:
The 3D-model part file contains some points, witch is visible on the drawing.
These points is manually selected, one by one, from the drawing.
The grip program should output the X, Y and Z coordinates to a text file.
Numbering of the points ( P1, P2.. ) shall be the same as the selecting order of the points.
Formatting of the file should be like this:
P1
X <coords>
Y <coords>
Z <coords>
P2
X <coords>
Y <coords>
Z <coords>
P3
X <coords>
Y <coords>
Z <coords>
P4
X <coords>
.....and continuing to the last point.
P1
X <coords>
Y <coords>
Z <coords>
P2
X <coords>
Y <coords>
Z <coords>
P3
X <coords>
Y <coords>
Z <coords>
P4
X <coords>
RE: GRIP program to read points coordinates and output to file
Ben Loosli
Sr IS Technologist
L-3 Communications
$$ SUBPROGRAM : SortProximityPoints.grs
$$ RELEASE HISTORY :
$$ 03-Jan-07 : Initial submission to library.
$$ AUTHOR : Zarko Smiljanic
$$ TITLE : Structural Designer
$$ COMPANY : Nika Inc
$$ 46 Lothian Ave
$$ Toronto, Ontario M8Z 4K1
$$ Tel : 416.231.8373
$$ SUBROUTINE :
$$ Variable Definition
NUMBER/ X(3)
NUMBER/ Y(3)
NUMBER/ V(3)
ENTITY/ SLIN
ENTITY/ SPTN
ENTITY/ PTS(1000)
ENTITY/ TL(1000)
STRING/ IMAG(2,80)
STRING/ NAME(132)
STRING/ GDE(132)
$$ Data Definition
DATA/IMAG,' No , X , Y , Z ',$
DATA/ GDE,'C:\Program Files\Microsoft Office\Office11\EXCEL.exe'
$$ Select Points
LOOPA: MASK/2
IDENT/'Select Points',PTS,CNT,IPTS,RESP
$$ Select Start Point
IFTHEN/RESP>2
IDENT/'Select Start Point',SPTN,RESP
IF/RESP==1,JUMP/LOOPA:
IFTHEN/RESP>2 AND SPTN<>&NULENT
DO/LOOPB:,I,1,IPTS
RAST=DISTF(PTS(I),SPTN)
IFTHEN/RAST==0
SPTN=PTS(1)
PTS(1)=PTS(I)
PTS(I)=SPTN
JUMP/ LOOPC:
ENDIF
LOOPB:
PTS(I+1)=PTS(1)
PTS(1)=SPTN
IPTS=IPTS+1
$$ Sort Points By Proximity
LOOPC: DO/LOOPD:,I,1,IPTS
&NAME(PTS(I))=ISTR(I)
LOOPD:
DO/LOOPE:,I,1,IPTS-2
C_DIST=DISTF(PTS(I),PTS(I+1))
K=I+1
DO/LOOPF:,J,I+2,IPTS
T_DIST=DISTF(PTS(I),PTS(J) )
IFTHEN/T_DIST<C_DIST
C_DIST=T_DIST
K=J
ENDIF
LOOPF:
SPTN=PTS(I+1)
PTS(I+1)=PTS(K)
PTS(K)=SPTN
LOOPE:
$$ Data Output
RPAINT
CREATE/TXT,1
WRITE/1,IMAG(1)
DO/LOOPG:,I,1,IPTS
X=&POINT(PTS(I))
WRITE/1,USING,IMAG(2),I,X
CRTWRT/ISTR(I),&POINT(PTS(I))
IF/I<IPTS,TL(I)=LINE/PTS(I),PTS(I+1)
LOOPG:
MESSG/ 'Press Any Key ..'
DO/LOOPH:,I,1,IPTS
LOOPH:
DELETE/TL(1..IPTS-1)
NAME=TIME
NAME=REPSTR(NAME,':','_',1)
NAME='C:\TEMP\Vector'+NAME+'.csv'
FETCH/TXT,3,NAME,IFERR,ENDE:
FDEL/NAME,IFERR,ENDE:
ENDE: FILE/TXT,1,NAME
FTERM/TXT,1
XSPAWN/CONCUR,GDE,NAME
RPAINT
JUMP/LOOPA:
ENDIF
ENDIF
$$ Program End
END: HALT
$$ PROGRAM: PointCoordinates.grs
$$ 12-Jan-01 : Initial submission to library.
$$ COMPANY : McDonnell Douglas CANADA
$$ 6972 Airport Road
$$ Mississauga, Ontario, L5P 1B6
NUMBER/ X(3)
NUMBER/ Y(3)
NUMBER/ Z(3)
NUMBER/ U(3)
NUMBER/ V(3)
NUMBER/ W(3)
NUMBER/ ILEN(3)
NUMBER/ IDECPL
ENTITY/ ENTY
ENTITY/ KSYS
ENTITY/ ENT
ENTITY/ LABELA(500)
STRING/ WVIEW(30)
STRING/ STATION(4,20)
STRING/ NOTA(10,30)
$$ Data Definition
DATA/STATION,'X #@@@.@@@@@@@@@@@@',$
'Y #@@@.@@@@@@@@@@@@',$
'Z #@@@.@@@@@@@@@@@@',$
$$ Active Part Check
IFTHEN/&ACTPRT==1
MESSG/'You don''t have an active part !'
HALT
ENDIF
$$ Read/Setup System Variables
IWLAYER = &WLAYER
IFONT = &FONT
ILWIDTH = &LWIDTH
ITLWID = &TLWID
ITEXTOR = &TEXTOR
ITDENS = &TDENS
ITXJUST = &TXJUST
IVTXJST = &VTXJST
IENSITE = &ENSITE
ICFONT = &CFONT
ICSIZE = &CSIZE
IDSIZE = &IDSIZE
&WLAYER = 201
&FONT = &SOLID
&LWIDTH = &NORMAL
&TLWID = &NORMAL
&TEXTOR = &TXBANG
&TDENS = &NORMAL
&TXJUST = &LEFT
&VTXJST = &TOP
&ENSITE = &MIDC
&CFONT = 1
&CSIZE = .1250
&IDSIZE = .500
ILABELA = 0
IDECPL = 3
&FILARW = 1
&ARIANG=20.
&ASIZE=.2
&TLWID=&THIN
&TEXTOR=&TXBANG
&ENSITE=&MIDC
&TDENS=&THIN
&VTXJST=&TOP
IRED=0
$$ Create Point Coordinate Label
LOOPA: &VWCURS = &ANY
&WCS = &ABS
&DECPL = IDECPL
MASK/2,3
IDENT/'Select Entity',ENT,CURSOR,X,MEMBER,OFF,RESP
JUMP/END:,END:,,RESP
&VWCURS=&ANY
WVIEW=&VWSEL
IFTHEN/ENT<>&NULENT
ITYPE=&TYPE(ENT)
X=MAP/X,FROM,WVIEW,TO,&CURDRW
IFTHEN/ITYPE==2
OBTAIN/ENT,Z
ELSE
OBTAIN/ENT,Z,U
ENDIF
&VWCURS=&WORK
POS/'Locate Label Origin',Y,RESP
JUMP/LOOPA:,LOOPA:,RESP
CREATE/TXT,8
DO/LOOPD:,N,1,3
NOTA(N)=SUBSTR(STATION(N),1,9+IDECPL)
WRITE/8,USING,NOTA(N),Z(N)
LOOPD:
RESET/8
READ/8,USING,STATION(4),NOTA(1)
READ/8,USING,STATION(4),NOTA(2)
READ/8,USING,STATION(4),NOTA(3)
FTERM/TXT,8
ILABELA=ILABELA+1
IFTHEN/Y(1)>X(1)
LABELA(ILABELA)=LABEL/LEFT,Y(1),Y(2),$
ENT,VIEW,WVIEW,NOTA(1..3)
ELSE
LABELA(ILABELA)=LABEL/RIGHT,Y(1),Y(2),$
ENDIF
IRED=IRED+1
PRINT/'P'+ISTR(IRED)
PRINT/NOTA(1)
PRINT/NOTA(2)
PRINT/NOTA(3)
ENDIF
JUMP/LOOPA:
$$ Reinstate System Variables
END: &WLAYER = IWLAYER
&FONT = IFONT
&LWIDTH = ILWIDTH
&TLWID = ITLWID
&TEXTOR = ITEXTOR
&TDENS = ITDENS
&TXJUST = ITXJUST
&VTXJST = IVTXJST
&ENSITE = IENSITE
&CFONT = ICFONT
&CSIZE = ICSIZE
&IDSIZE = IDSIZE
HALT
