Dynamic Simulation
Dynamic Simulation
Hello!
I have a crane model here. I want to use FEA to calculate stresses and safety factors for the upper beams and do it through a dynamic simulation. The problem is that it seems that I can use in simulation only components that belong to the main assembly but not to some of subassemblys!? Is that true? Always when I try to pick one of them IV tells me that: "The part is in a subassembly"... or similar. How to overcome this? See my simple model: ht tp://img63 .imageshac k.us/my.ph p?image=cr anetl4.jpg
RE: Dynamic Simulation
I don't think adaptivity and flexibility have anything to do with it, but I stand to be corrected.
The analysis will be assuming fully bonded parts at the interfaces.
Inventor Pro does not provide surface to surface contact modeling.
Hope this helps.
tg
