Control of scale & corrosion for the generating plants
How do you control the scale when water is heated to produce steam to generate electricity? Will a magnatic device control the formation of scale?
salesman
RE: Control of scale & corrosion for the generating plants
Water chemistry is a major concern and expense for steam boiler operators. Most large boilers have continuous sampling system to automatically monitor and control water quality.
I'm not sure hydrazine is used much any more, at least in the US, due to its hazardous nature, but I could be wrong about that, like a lot of other things.
dpc
http://pe.pennwellnet.com/Articles/Article_Display.cfm?Section=Articles&SubSection=CurrentIssue&ARTICLE_ID=137235&VERSION_NUM=1
Blacksmith
