Flat Out Pattern for Eccentric Reducer Calculation
Does anybody know the way to determine flat out pattern of an eccentric reducer? Assuming that the small OD is 5" and big OD is 12". Thanks
RE: Flat Out Pattern for Eccentric Reducer Calculation
good luck
No, you way does not work out right. Yes, the base is parallel.
Your answer is ambiguous. If my way did not work out right, were you able to solve the problem by building a simple paper model ? Seems like you should be able to.
good luck
I know the way to calculate the flat out pattern of a CONCENTRIC reducer, but not for ECCENTRIC reducer.
http://virtualpipeline.spaces.msn.com
The page presents a visual outline of the technique, which is probably not real clear if you haven't ever done it.
Mike Halloran
Pembroke Pines, FL, USA
