Fitting dimensions
Fitting dimensions
Fitting dimensions
Pipe Fitting dimensions in the web?
RE: Fitting dimensions
Contact Ms. Donna McMahon (dmcmahon@micoks.net) at Taylor Forge and request a pipe fitting dimension chart.  She will send you a PDF file (Adobe Acrobat) that you can put on your hard drive with a shortcut for your desktop.  You will need the free Acrobat viewer to use the file.  You will find this chart very useful.
Regards, John.
Thanks John...
Thanks I have been looking for a new one for 25 years, I even appoached the company and they told me they had quit supplying them.
