Scaling part in same file
Can I scale a part within that file (part file) itself?
RE: Scaling part in same file
No, but you can
Start a new part file
Insert a Part Copy
Change the parameters for Scaling.
The inserted part copy will be linked to the feature-based part, if you want it to be.  Any changes in the base part will be reflected in the copied part.
--Scott
http://wertel.eng.pro
...but keep in mind: everything gets scaled ...
dy
