Locating the Row Number of PageBreak
How can I locate where the horizontal page break is using a VBA code.
In other word, I am trying to find where
ActiviSheet.HPageBreaks(2).Location is.
When you set up the page break the syntax is
ActiviSheet.HPageBreaks(2).Location = Range(Col, Row)
Col is always "A"
I want my macro to recognize the row number.
My many attempts have been unsuccessfull.
Many Thanks
FM
Col is always "A"
Many Thanks
FM
RE: Locating the Row Number of PageBreak
Hi FM:
Try ...
CODE
I hope this helps.
Yogi Anand, D.Eng, P.E.
Energy Efficient Building Network LLC
ANAND Enterprises LLC
http://www.energyefficientbuild.com
I tried it. It gives me a message that "Subscript Out Of Range".
I am trying to use it in a loop so when the code reaches a page break on the sheet it will skip the following 2 (or n) rows and go back to doing what it, hopefully, is supposed to.
Thanks again, I'll keep at it.
FM
I suggest you post your code (with a brief background/description) and point out where it is giving you the error -- and then let us take it from there.
spacing is along a row of piles
LL is the distance from the origin of the pile row to the row in the other direction.
this code works.
I am trying to add a step where when the code is filling in the cells with pile coordinates it will skip 2 lines when it gets to a page break and resume with the next I .
I should have posted this to begin with!
Thanks very much.
Sub CORDNT()
NoPiles = ActiveSheet.Range("C5").Value
Spacing = ActiveSheet.Range("D5").Value
LL = ActiveSheet.Range("E5").Value
LTT = (NoPiles - 1) * Spacing
J = 1
For I = 0 To NoPiles
Range("G1").Offset(J, 1).Value = (LTT / 2) - (I * Spacing)
Range("G1").Offset(J, 2).Value = LL
J = J + 1
Next I
End Sub
