gradient OPGRAD
gradient OPGRAD
gradient OPGRAD
Hi, How stores as a parameter the result of exit (of the archive OUT) referring to the calculation of the gradient (0.3253E-04, 1,000, -99,08), when uses the tool OPTYPE,GRAD of the optimization command? Stretch of an archive OUT goes in annex.
PRINT RESULTS FOR GRADIENT EVALUATION FOR RESPONSE VARIABLE =GU
 ********** GRADIENT EVALUATION RESULTS **********
  REFERENCE DESIGN = SET    1
  GRADIENT RESULTS = SETS    2 TO     4
   U1                              = 0.21000E+06
   U2                              =  280.00
   U3                              =  1.5000
 ***** FOR THE OBJECTIVE FUNCTION GU       (REF. VALUE=  138.2    ) *****
 CHANGE IN VALUE (DUE TO +1% CHANGE IN DV)            GRADIENT
   PER DESIGN VARIABLE U1                              : 0.6832E-01         0.3253E-04
   PER DESIGN VARIABLE U2                              :  2.800              1.000
   PER DESIGN VARIABLE U3                              : -1.486             -99.08
 PROVIDE DETAILED OPT SUMMARY PRINTOUT INCLUDING ALL DESIGN SET LISTS
 *** EXIT FROM ANSYS DESIGN OPTIMIZATION (/OPT) ***
