Importing Data into a Pro/Table Pattern, Rounds to 3 decimal places
I created a table pattern at the part level. I formatted a text file and saved it as .ptb to import into the pattern table (as desribed by Hora in thread554-11277: Using Excel to create/modify pattern tables?).
My problem is that when the file is read into Pro/Engineer, the values are all rounded to 3 decimal places. Is there a way to keep this from happening, or to increase the number of decimal places?
thanks,
David Garber
thanks,
David Garber
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
RE: Importing Data into a Pro/Table Pattern, Rounds to 3 decimal places
That is exactly right. Pro/E was rounding to the accuracy of the dimension property. And you can actually change it even after creating the pattern.
Thanks again...
