wood piling repair
wood piling repair
need to repair saltwater dock's wood pilings. plan on using pvc pipe to encase existing wood pilings that is 6 inches larger diameter than existing wood pile. place steel reinforcement rings attached to vertical steel inside pvc pipe. then fill with concrete (piles are exposed at low tide so will fill pipe at low tide. piles are 12 feet above mud line. piles support walking deck 6 feet high and have about 60 percent of cross section remaining. any suggestions?
RE: wood piling repair
If you go your way I would get some help on the cement grout that will be required.
Here is a company that has many ways to skin a pile.
http://www.densona.com/DensoMarineSystems.htm
http://www.osmose.com/utilities/
Next time please start a new thread instead of tacking it on to an existing one. You will get a lot more responses.
