Hydraflow Hydorgraphs 2007
Does anyone know how to augment the program to route 150% of the 100-yr design storm?
RE: Hydraflow Hydorgraphs 2007
What method are you using to generate the hydrograph ? What duration ? If you're using the Rational Method, and the drainage area is small enough that this is appropriate, then Francesca's suggestion may work. But if you're using other methods you may find it easier to change the rainfall amount in Event Manager.
good luck
