Rebuild Errors w/SP4
I have begun to notice some parts that were created pre SP4 with "questionable Geometry" now blowing up in SP4.
They will blow up on machines with SP4 but when I load them on a machine with SP3.1 they are fine.
FYI
RE: Rebuild Errors w/SP4
What do you mean by "questionable Geometry" ?
cheers
I guess I mean, I can understand why it would blow up.  It looks like it should have blown up but it never did until SP4.
Maybe they have built more "intelligence" into SP4 ... or tighter rules?
I'm curious, can you show an example of the "questionable Geometry"?
cheers
This image shows the "QG"  It's the area where the lofted cylinders change direction to form a sweep:  This was fine in SP3.1
This is the modified version:
