corrupt file in data manager - want to delete
I have 2 corrupt files in my data manager. During interoperate, "Get from library has failed" comes up. I want to delete these 2 files & reload the package. The import/export check is on (lock/unlock option in manage libraries) when I try to turn this off, it says "Item is currently used by another user". This is a stand alone machine with classic TDM. Any ideas on how to get around this?
Thanks.
Thanks.
RE: corrupt file in data manager - want to delete
To delete a model file you have to go to the main menu and file/manage, click "modify" on the upper right, select the model file you want to delete and on "actions" choose delete. If the parts you want to get are in this model file, you will be able to check them out once you delete this model file.
If this doesn't work there are other things to do.
