fermentor sparger design
90m3 volume of liquid,air supply 4000scfm at2.5 barg,25 deg c temp.152mm pipe size,kindly suggest size and number of holes on sparger.
RE: fermentor sparger design
If 3/16" Dia. hole (4.8mm) drill 797 holes
If 1/4" Dia. hole (3.44mm) drill 448 holes
Hope this helps.
Could u please apprise the way/method you arrived at the above answer.Relevent books/articles will do.
Thanks in advance
SALKO
CHEMICAL ENGINEERING MARCH 9,1981 ,116-117
CHEMICAL ENGINEERING APRIL 6,1981, 93-95
CHEMICAL ENGINEERING NOV17,1980, 277-281
SALKO
